need electrical help - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 06-20-2016, 01:26 PM
win win is offline
Default need electrical help
I have a 2006 ranger 500 4x4. I found out yesterday that when I turn my lights on it goes into 4 wheel drive. So I started probing wires. With all the switches turned off, and the key to the on position, I have a hot wire back to the taillights and I can hear the rear end solenoid click in whenever I turn the key off and on, is this the way it is suppose to be. If it is, what is the solenoid in the rearend doing. thanks
Old 06-20-2016, 01:46 PM
Rear differential lock. Should have that switch on the dash if I remember correctly. Item #32.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories Cycle Parts Warehouse if you need a manual with the wiring schematic here's one for 10 bucks.2006 Polaris Ranger 500 4X4 CARB Service Manual PDF Download If you have the efi model.2006 Polaris Ranger 500 4X4 EFI Service Manual PDF Download
Thread Thread Starter Forum Replies Last Post
07 Kingquad 700 Starting Issues abillman Suzuki 9 03-30-2016 02:48 AM
2003 Sportsman HO 500 - rear break bleeder screw stuck grangerboy Polaris 7 03-29-2016 10:21 PM
How much for a rear axle installed?? slowjoe41 Honda 3 03-25-2016 05:37 PM
Loncin 110 ATV starting issues, need help. Leavitt Woodland 1) Engine problems.. 1 03-24-2016 02:55 AM
Rear Motor Bolt 22Driver CAN-AM (BRP) Ask an Expert! 0 03-22-2016 01:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
