Octane additive in 2-stroke?-WARNING - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 09-10-2004, 07:16 AM
jimmypsp700's Avatar
Default Octane additive in 2-stroke?-WARNING
I usually run super unleaded 92-94 octane gas in my Scrammy (Trail pipe etc..) but when I just use regular I put a octane booster additive in. The problem being, I seen on the label of one brand to NOT use in 2 stroke motors. Now is this all octane additives or just that brand? Will it hurt my 400cc 2-stroke?
Old 09-10-2004, 09:51 AM
my town only sells 91 and thats what i run now, but how much octane booster do you put in?
i couldnt tell you if it hurts your engine or not....have to get a professionals opinion.
Old 09-10-2004, 09:54 AM
I also use 92 octane from the pumps, and sometimes use "boost" or "stp110" fuel boosters.......I think they are just giving a general warning. I know these products I listed can be used. I suppose that a 2 stroke burns hotter and revs higher, causing them to warn the customer that too much octane booster will probably cause a meltdown(in other words, you can't run the stuff strait).
I know you can run vp fuels, like the 110 stuff, in 2strokes, because I've done that before.
Old 09-10-2004, 10:31 AM
If you REALLY NEED higher octane, you MUST use a booster formulated for 2 stroke use. Regular octane boosters, formulated for 4 stroke use, do not allow all three liquids (gas, oil, booster) to mix properly resulting in an over lean condition and ultra high combustion chamber temps.
Unless it's specifically made for 2 stroke use...... DO NOT USE IT!!!!
(Out of curiosity.... Why are you using octane boosters? Head work? High compression? Advanced ignition? Or does it "just run better"? The reason I ask is that I have a "BUILT" Yamaha triple (Outboard motor) 14.5:1 compression, worked over heads, advanced ignition, triple exhaust tuners....... And it runs just fine on pump mid grade gas, 89 to 90 octane.... I tried 92 octane once and proceeded to foul the plugs in a heart beat. What is the comp ratio in a 2 stroke Scrambler anyway?)
Old 09-10-2004, 10:45 AM
I have never found an octane booster that added more power or decreased *pinging* .
I have mixed racing fuel with premium gas and had good results with that . Although I have been told by chemists with more knowledge than I that this is not a good idea .
Rick
Old 09-10-2004, 02:36 PM
klotz octane booster,real 2 stroke stuff,with retarded timing
it help to cool down a bit.2-3 ounces of it is enough.
octane is needed when high comp. heads is on.less prone to detonation.
Old 09-10-2004, 04:19 PM
RAJ RAJ is offline
I always ran VP octane boost, and turbo blue racing fuel. I never had a problem.
Old 09-13-2004, 03:29 AM
It's an automotive octane booster and I only put the recommended amount in. With my mods HPD recommends 92 octane on the installation paperwork. I haven't had any problems yet and it runs good. I haven't seen any recommended for 2 or 4 stroke but again its automotive, I need to check the stuff at the MX store. Although with Ricks post I'll probable just run the pump premium fuel from now on.
Thread Thread Starter Forum Replies Last Post
Dealer rejects my offer of $16,403.33 cash :( Johnny Mac Honda 4 10-06-2015 07:53 PM
My Race Write-up from Crafton 1 (TORN Series Rd 4) MikeyBoyesq ATV Racing 0 09-07-2015 10:44 PM
Tmx 42mm jetting Polaris-400 Introduce Yourself 2 08-19-2015 02:20 AM
Tmx 42mm jetting Polaris-400 Polaris 0 08-16-2015 05:15 PM
Answered: Why No Fuel Injected 2-Strokes? ATVC Correspondent Ask the Editor 12 07-21-2015 06:57 AM
Tags
2 , 2stroke , boost , booster , boosters , boster , cycle , engines , mx , octaine , octane , outboards , stroke , strokes , work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
