Can a plow be put on a trailblazer 250?
ya, it just really wont be enough power to do a whole lot.. In my opinion it would be a waste of time and money to throw it on the blazer. They usually sugest something with about 400 cc for plow use...I've seen some 350cc with plows that wern't to bad.
I have the cycle country plow on my 250 with the 48inch blade. I do just fine and last winter i made about 400 bucks from plowing. The plow i have has the manual lift so you just pull the the lever to drop it or bring it up. Its easy to install it takes me about 2-3 minutes so hook everything up or unhook everything. All i do is lower the rear tire pressure a little and i can hook up pretty well and push a lot of snow. I will be putting the plow on soon so if you want i can take some pics to show you.
Well you would be the first one i talked to that has had 1. That is the brand i was also looking at. Yours looks like it has alot done to it.
Mine is 100% stock and staying that way. Stock do you still think it would push ok? Thanks for the responce.
