Improved Sportsman headlight Bulbs
A Polaris will eaisly pull two 55 watt bulbs and keep the battery well charged. It will not pull three 55 watt lights unless you are running at a very high RPM at all times.
I will concede. Maybe cornbread2 is right and you can get 27 watt bulbs from an autoparts store to replace the OEM bulbs for the low beam bulbs. I beg to differ considering most automotive bulbs are regulated at 55 Watts, but none the less cornbread2 has yet to tell us all, the type and manufacturer of those bulbs. Funny?? You state you have aftermarket lights and still run those wimpy OEM lights. Whats up?? I recognize the concerns that many Polaris owners have had in the deficiency of light in the stock low beam bulbs, and have found the exact 55 watt replacement bulb. And I agree with Sportsman EE that at idle you dont want to have these on long; it may tap your battery. But maybe Im different. I ride with my lights on in the dark when Im moving !!!!
#17
#19
I have it and Im tryin to break even for what I spent. So bad????
#20
Originally posted by: STSACER
cornbread2, its about u talkin about something you dont know. If you did you would give the info. I have it and Im tryin to break even for what I spent. So bad????
I have been doing this for years. I know plenty about lights on ATV's.
I also know I can get these bulbs from many different places without having to pay you for info.
As I said MANY times before but you just don't seem to get the point, these high power bulbs are avalible from most any place that sells ATV and motorcycle stuff and those sorces have already been posted by others on this thread.
We are not going to pay you for this info. Get over it and try to sell your BS somewhere else.
