polaris sportsman 500 Motor boggs bad when i give it gas
Old 11-01-2005, 12:22 AM
sgajan's Avatar
Default polaris sportsman 500 Motor boggs bad when i give it gas
powerslider,,,Ok I will check that...thanks
  #42
Old 11-01-2005, 12:11 PM
rungunner's Avatar
Sgajan,
I have almost got it. New needle installed. The machine is running about 90% better. I also ran motor while unplugging transmission switches one at a time, It seems like it has something to do with one of these switches. This is one of those things where we have to eliminate things. I am waiting for parts for the clutch so I can ride it and see how it does. Did you check and set your valves? and check for a worn out cam? Exaust lobes worn out?
  #43
Old 11-01-2005, 12:47 PM
Kerbbirds's Avatar
thought you said it was a sportsman 500, they dont have oil injection they are 4 stroke. If the needle and seat go bad they fill the engine oil with gas, take the cap off where you check tne oil and see if it;s overfull and smells like gas if so change needle and seat in carb and change engine oil.
  #44
Old 11-01-2005, 06:50 PM
sgajan's Avatar
it is a 4 stroke..with the oil cooler tank on the side .. thats what i meant...good catch
  #45
Old 11-01-2005, 06:52 PM
sgajan's Avatar
Rungunner,,,,did your bike have enough power to move before you replaced the needle? this one wont even engage the clutch because it doesnt get to high enough rpm..
  #46
Old 11-01-2005, 08:50 PM
powerslider's Avatar
Another thought, make sure the exhaust isn't plugged/restricted....
  #47
Old 11-01-2005, 09:08 PM
sgajan's Avatar
powerslider,,,yeh i tried that ...its clear though.
  #48
Old 11-03-2005, 04:23 PM
rungunner's Avatar
Sgajan,
Did you check and set the valves? Did you run the machine and unplug the switches one at a time on the transmission? I am still working on this one a little at a time. Waiting for clutch spring still so I can ride it and fine tune the carb. You moved the needle clip all the way to the top and it did not run any better? It is hunting season and not much time to work on it.
Rungunner
  #49
Old 11-04-2005, 09:31 AM
sgajan's Avatar
rungunner,,, yeh the valves are set,,i raised the setting on the needle to the top position and i unplugged all kinds of wires and nothing...he needs to go and buy some parts now...i still think its flooding,,,
  #50
Old 11-04-2005, 09:37 PM
rungunner's Avatar
Sgajan it can not be to much gas if it is backfiring. This is a lean condition (not enough gas and too much air). There are some people I have talked to and told me that the exaust lobe could be worn right off the cam that it was common for this year Polaris. I have not checked mine yet. Another thing I would like to try is a carburator from another machine. I have never had trouble solving problems with any machine but this one is pretty weird. I am going to be away for 1.5 weeks so I will sign off for now but keep me updated if you find anything as I will check this site when I get back from my hunting trip.
Quick Reply: polaris sportsman 500 Motor boggs bad when i give it gas
