Do 26' 589s fit on stock 05 sp 800 rims
Old 11-15-2005, 07:50 PM
spyder6's Avatar
Default Do 26' 589s fit on stock 05 sp 800 rims
well mine were like 7 or so when i measured them, i was going to get mudlite's but decided to get the predator instead
Old 11-15-2005, 08:02 PM
powerslider's Avatar
The width measurement is taken between the rim beads not the outside of the rim. 12x6 is what comes stock on front of the 800's.
Old 11-15-2005, 09:00 PM
spyder6's Avatar
well... shat...
still shouldent be rubbing anything else than the shocks though
Old 11-15-2005, 10:10 PM
TJ700's Avatar
the problem is in the rim.
has to be.
my friend bought a new set of tires, thought it was the PXT's.
the new tires are still going flat.
  #15
Old 11-15-2005, 10:48 PM
spyder6's Avatar
shouldent be the rims, their manufactured by Vision, the only design polaris had in it was the spoke set up, the rim itself is a old design of visions
  #16
Old 11-16-2005, 07:18 AM
floodrunner's Avatar
I’m going to qualify this statement before I make it because it’s hearsay. I have no first-hand experience with the early 800 wheel problems I’ve heard about but I’ve heard there are problems, and on the later 800s Polaris has changed the design to correct them. The problems were not holding air and pinching / cutting sidewalls when riding in rocks.
I know you have some sharp looking aluminum wheels there and it bites to have to replace them but if you’re going to a wider tire I suggest you put them on aftermarket wheels to avoid the leakage and clearance issues. Aftermarket wheels for Polaris are 7” wide front and rear and have a 1” farther to the outside offset than stock which keeps those wider fronts away from the tie rod ends.
If you put the 9” wide fronts on the stock wheels the inside wall of the front tires may clear the tie rod end but by how much? If it’s less than ¼” you can expect to be tearing up your tie rod end boots when you get in the mud. I put 28 x10 Mud Lites on aftermarket wheels on the front of my ’05 700 for a while. They cleared the tie rod end boot by ¼” or less but when the tire picked up mud while riding through the slop the clearance went away and the result was torn tie rod end boots, and soon bad outer tie rod ends.
  #17
Old 11-16-2005, 08:20 AM
spyder6's Avatar
thanks for clearing this all up floodrunner
  #18
Old 11-16-2005, 10:51 PM
TJ700's Avatar
a few washers behind the wheels will clear a 9" tire. its close, but clears.
  #19
Old 11-17-2005, 11:37 AM
JASON420Z's Avatar
Thanks guys! I think I need to just slime all 4 tires use up the tires as much as possible and get new ones (maybe something in 14") when i need to. I just get sick of getting stuck in holes that a 600 sp with 589s can walk through, but i dont miss the rough ride on the hard packed dirt or the flip your bike over on steep hill traction. Fact is that as men we could have bullet proof carbon fiber plastics and kevlar lined tires with 2.5" lugz that ride like a new set of Mischelins and we would still find something we want more, so with that said i think Ill just get a nitrious system installed a just go across the top of the puddles, lol.
dannytas
09-26-2017 06:31 PM
Pehter
09-04-2016 08:22 PM
PinkFloydEffect
09-25-2015 06:31 PM
XxS0ccerstarxX
09-24-2015 11:53 PM
Todd C Wadas
2) Chassis problems..
09-23-2015 11:31 PM
Quick Reply: Do 26' 589s fit on stock 05 sp 800 rims
