Do 26' 589s fit on stock 05 sp 800 rims
Old 11-10-2005, 12:23 PM
JASON420Z's Avatar
Default Do 26' 589s fit on stock 05 sp 800 rims
Im looking at getting 26" 589s for my 800. My pxts have had problems holding air since day 1, my beads have more tree bark, rock and mud in them the trails i ride on. Just wondering if they fit on the front, stock are much narrower then the 589s.
Old 11-10-2005, 05:47 PM
kj2053's Avatar
I hope so...........I just ordered 589's- 26x9x12's for the front & 26x12x12's for the rear. I asked the sales person that same ? and he said yes they would fit. I hope this answers your ?
Old 11-10-2005, 06:33 PM
JASON420Z's Avatar
I think the front rims are 8" so they should fit on the rims. My concern was that the ITP C-Series rims that the tires are on now are off set and it looks like the tires would rub on the tie rod ends if they were on stock rims.
Old 11-10-2005, 08:09 PM
spyder6's Avatar
yes they fit
Old 11-11-2005, 12:00 AM
elkbow's Avatar
yes they will fit
Old 11-11-2005, 01:12 AM
JASON420Z's Avatar
Thank you for the assurance. I was hoping one of you two would respond, it was nice to see both of you did, I've learned alot from both of you. Thanks again.
Old 11-15-2005, 12:17 PM
kj2053's Avatar
26x9x12 589's do not fit on the front of a stock SP800, the front tires hit the tie rod end, you have to buy a set of spacers. The 26x12x12's fit perfect on the back. I tried washers on the front studs but ran out of room so I had to order a set of $79.95 spacers for the front. FYI.....
Old 11-15-2005, 02:33 PM
kj330's Avatar
I HAVE AN 04 700 AND THE 26" 589 HIT THE TIE RODS. ON THESE MACHINES A SET OF 79.00-129.00$ ONE INCH WHEEL SPACERS MAKE THE MACHINE ALOT BETTER HANDLING ANYWAY. THE REARS ARE FINE.
Old 11-15-2005, 05:09 PM
spyder6's Avatar
they will/should fit on with no problem, the stock front rims are 8" wide and the front tires are 8 as well. the 05's had widend front ends so if anything it should be rubbing the struts if it rubbed at all
Old 11-15-2005, 06:58 PM
powerslider's Avatar
Stock front rims are 6" wide....
Quick Reply: Do 26' 589s fit on stock 05 sp 800 rims
