scrambler 500 no spark
Yes you have to pull the flywheel to get to the stator..This is not a real big job..all you need is a small puller...the coil-pulser (pick-up for the coil) my be jerked out of position...this is what I normally find..Just make sure you put it back at the proper clearence around 45 thousands.I think that is what the setting is..Hope this helps..
#15
The puller will use three bolts that screw into the magneto. before you try all of this, have you unhooked the black wire on the cdi? That is the main kill wire. it works all of the kill switches and limiters. If that does not make it have spark, then it leaves you with stator, coil, or cdi problems. Just thought that would help, and it takes a few seconds to do it
#18
#19
