antifreeze in oil 2003 & 2004 700
Old 04-16-2006, 03:37 PM
Sidekickmechanic700's Avatar
Default antifreeze in oil 2003 & 2004 700
UTU- "Breather Line replacement" what breather line is that for? just wondering if i should get that replaced or not.
Old 04-16-2006, 06:14 PM
UTU's Avatar
UTU
UTU is offline
600/700 service bulletin #S-03-05.
All 2002/2003 600-700's are covered by this and certain 04 600/700 it came out 12/11/03 This covers any machine that is ridden where they have a chance of being in below freezing weather.Talking about condensation that can accumalate in the crankcase breather hose, it may freeze cause water in oil and pressure build up in the crank case. Recall seeing some of these machine that had blew the oil and water seal, oil stain was coming that was on the side of motor.
POLARIS is saying is that EXCESS PRESSURE and WATER in the crankcase could cause oil loss and severe engine damage. Take Care!
Old 04-17-2006, 01:55 AM
i guess i should call the dealer and see when i can get it in, since i live in MN and it gets damn cold in the winter months.
Old 04-17-2006, 10:13 PM
Andre's Avatar
Hey Sidekick, just make sure your crankcase vent line doesn't have a "belly" in it enough to cause condensation to puddle, freeze and block the line. Most of the twins I've looked at have a straight path with little chance of condensation accumulating and freezing in the tube.
I modified my stock tube by making a 1/2 slit with an Exacto knife about 2" from the valve cover end of the tube. This slit will allow crankcase pressure to escape incase of blockage. The vent tube is thick enough that the slit will remain closed and not allow stuff to enter but will allow built-up pressure out and is basically what Polaris did to fix the problem.
If you can get your dealer to order an updated breather line, go for it, I have not had much luck with my dealer.
  #15
Old 04-17-2006, 10:58 PM
thanks for the tip Andre, i'll do that if my dealer doesn't want to work with me.
my breather line seems to have a nice flow to it, and hasn't giving me problems yet, 4 years and going strong seems good. i probably will never bring it in.
2many2ride
09-27-2015 04:35 AM
exmotocrosser
09-26-2015 08:18 AM
Bernhard
09-25-2015 12:45 PM
Sw00p
09-24-2015 02:50 PM
Hw00d
09-10-2015 08:53 AM
Quick Reply: antifreeze in oil 2003 & 2004 700
