Reverse shuts off engine...???? Help!!
#51
#52
#53
#54
I laughed my head off when I read it...Craper........
I didn't think they would allow that name or I could have used it...LOL..LOL....Caper having a Craper.......
Just give me some private time please...LOL...LOL.....
I was just kiddin' with the exlax-rider ......Hope you laughed at that and didn't take it at heart!!!!!!
#55
#57
#58
Originally posted by: cornbread2
You keep asking questions about your combo switch on your handlebars. You DO NOT have a problem with your combo switch.
Do NOT unhook anything from the switch. Do NOT attempt to take it apart.
I am buying the box.....which incorporates the following. The rev limiter, Headlights, and start switch. This was what I assumed you meant to replace. I have no clue what you are talking about when you throw in the "combo switch" terminology. You indicated not to waste time with replacing switches.....just replace the box. I am under the assumption that the combo switch, and the below listed part are the same.....Nothing else at this address (http://www.donwoodpolaris.com/fiche_section_detail.asp) fits the description.
Is the following what I need??????? Thats all I can find that matches the description of what you are talking about.
SWITCH-HANDLEBAR,H/L/O,REV/OR
4010262 1 $109.19
Thanks
#59
Everything on your handle bars are fine. The black box cornbread is refering to is under your front plastic. You have to take the cover off that is under your headlight pod to see the box. Your switches are working ok because when you press the switch it bypasses the box allowing you to stay running. Hope this helps clear up the confusion. TORK.
#60
