sportsman 500 rear end fluid
Old 04-16-2007, 07:48 PM
edmo500's Avatar
Default sportsman 500 rear end fluid
what type of fluid should I use in the rear end of my sportsman 500? any suggestions? is it real important to change?
Old 04-17-2007, 02:23 AM
Krammer220's Avatar
If you have an older Sportsman(with the integrated rearend & tranny..you wanna use Polaris AGL fluid or a quality "chaincase" fluid...Amsoil etc..)
If you've got the newer style (w/the separate rear & gear box) I believe you use any synthetic 80-90 gear oil in the rear & the AGL in the tranny
.....not sure what year they went to the separate boxes...I've got a 2000 with the integrated rear
Old 04-17-2007, 06:54 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
and yes its a good idear to change the fluid if you havent done it for a long time.
Old 06-15-2008, 02:21 PM
ccolt1's Avatar
Does the 2008 500 ho carb model have seperate fluids for tranny and rearend? I have seen a check and fill plug hole on one side and what I think is a drain plug hole on the right side.I do not see anymore.It seems like it is all one fliud. Thanks for any help!
Old 06-15-2008, 06:31 PM
sheepdogMSP8117's Avatar
Its all in one.
Jmuddin284
06-28-2017 04:59 PM
Sandman2.0
07-21-2015 09:03 AM
WilliamBos
07-13-2015 02:11 PM
rcappie4
07-10-2015 04:54 PM
Rider252
07-06-2015 03:37 PM
Quick Reply: sportsman 500 rear end fluid
