Polaris rear work light
#22
work light
I just ordered a Polaris work light kit for my 07 sportsman 500.
From Quadovator:
ATV parts, ATV tires, Quadovator ATV Accessories
From Quadovator:
#23
#24
#25
Rear Light Mod
Did a search on the old posts and found this one. Hope it helps!
[img]i/expressions/face-icon-small-blush.gif[/img]n my '03 600, I tapped the purple wire running from the trans. switch as a ground, then ran a fused wire to 12v off my tailight/brakelight wiring. When you shift into reverse, the purple wire grounds completing the circut. Works great when plowing snow (no toggle switches to fumble with) and trail riding (other riders coming up behind you can tell your in reverse and to use caution) Did this mod to mine just after I bought it new . No problems, just be sure to seal up all your connections good. Hope this helps. Later
#26
that is only true for the older style sportsmans Switz, for the newer ones, I believe a relay is required, so it's just as easy to buy the kit from quadovator, or you could just buy the bulbs and switch
Also, I haven't seen the bulbs posted yet, so you need 2 GE 912 or 921 bulbs, the 921's are brighter, and a water proof switch, I got a normal toggle switch, and then a rubber boot, to make it water proof all for about $10 or so
#27
#28
#30
whitty
67
02-24-2021 02:52 PM
hoopduerr
06-10-2015 03:00 PM
