No Spark!!
Old 08-27-2008, 11:53 PM
bowkiller's Avatar
Default No Spark!!
I have 2003 Polaris magnum 330. I have no spark, I replaced the coil because it was in bad shape I eliminated the brake switch and park switch that have to be engaged in order for it to start. Can anyone tell me how I should go about checking the stator? Any suggestions would be greatly appreciated.
Old 08-29-2008, 01:30 AM
ATC250R4ever's Avatar
Default No Spark!!
Put a volt meter on your stator's output and spin your engine. If you have voltage, your stator is good. Do the same with your coil, cdi, etc. Also, I know it sounds silly, but check the battery, make sure it's fully charged, or you'll have no spark (@ less than 12v).
Old 08-29-2008, 11:45 AM
03scrambler500's Avatar
Default No Spark!!
ohm check the pick/pulser up coil.
fordfaithful21
12-07-2015 05:52 PM
NRA+1
1) Engine problems..
10
09-20-2015 08:47 PM
Cdenton
Technical and How-To Articles
09-09-2015 11:23 AM
MrTrashMan2U
09-09-2015 11:11 AM
jeff mc
Dunes and Dune Machines
09-03-2015 07:47 PM
Quick Reply: No Spark!!
