Disconnecting Oil Injection
Old 09-08-2008, 06:06 PM
Capt.Cook's Avatar
Default Disconnecting Oil Injection
I have a 1994 Polaris 400 Explorer that smokes like a mosquito sprayer and fouls the plug in just a day or two.It has fouled plugs since it was new but has gotten worse with time.I dont think the oil injection is working right and would like to do away with the injection and mix with the gas.Can I just drain the tank,disconnect the oil line?What ratio do I mix oil/gas.
Old 09-08-2008, 06:20 PM
kukerdan's Avatar
if its fowling plugs i doubt its the oil pump, more likley your carb.....
rebuild that thing, and jet it for your altitude and mods, its not getting enough gas if its fowling, or its pulling way to much of both.
Old 09-08-2008, 08:58 PM
Koerbs's Avatar
Just unhook the cable that opperates the oil pump, and mix your gas at 50 to 1. No reason to rebuild anything, this way you never have to worry about your oil pump failing.
Old 09-08-2008, 10:02 PM
user493's Avatar
Moto Psycho
It may just need to be adjusted.
exmotocrosser
09-13-2019 06:12 AM
Jackg17
Ask the Editor
07-16-2018 04:01 AM
Jackg17
09-26-2015 09:30 PM
rockinkgin
09-25-2015 01:52 PM
MrTrashMan2U
1) Engine problems..
09-09-2015 11:11 AM
Quick Reply: Disconnecting Oil Injection
