425 Magnum tech questions
Old 09-24-2008, 04:48 PM
tater34's Avatar
Default 425 Magnum tech questions
You probably have the same problem I do, exhaust lobe worn off on the cam.
Old 09-24-2008, 04:50 PM
AlkyBurninX's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tater34
You probably have the same problem I do, exhaust lobe worn off on the cam.</end quote></div>
Cam is brand new.
Old 09-24-2008, 04:52 PM
<div class="FTQUOTE"><begin quote>Originally posted by: MagnumPO
160 psi seems awful high, </end quote></div>
I was thinking that as well. I didn't put the new cam in, so I wonder if it is possibly degreed wrong, causing the high cranking pressure.
That still doesn't explain why its blowing oil out of the breather.
Old 09-24-2008, 08:37 PM
MagnumPO's Avatar
on my 500 there is a crankcase breather filter on the left side, it looks like a fuel filter, maybe thats stopped up.
  #15
Old 09-26-2008, 11:12 AM
MagnumPO's Avatar
the book says that for abnormally high compression it is either a damaged or worn exhaust cam lobe or a decompressor malfunction. it is blowing into the box because of the high crancase pressure, its blowing back up the vent.
  #16
Old 10-03-2008, 12:30 PM
The problem is its not scavenging oil from the crankcase. There is a little coming out of the oil line going to the tank, but not as much as there should be. I don't know if the oil screen is clogged, or what the issue is.
cornermike
09-10-2015 08:30 AM
Bigtwin700
09-09-2015 09:32 AM
09-09-2015 06:57 AM
Rooky
09-09-2015 03:16 AM
blueandy88
08-31-2015 12:42 PM
Quick Reply: 425 Magnum tech questions
