03 Sportsman 90 tail light
Hi all
First-time poster. Lots of great info on this forum. Thanks to all of you who take the time to share your knowledge and experience!
The tail/running light on my son's Sportsman 90 quit working.The light still works when the brake is applied.
I pulled the tail light cover off and the bulb filament was not broken,but the bulb would turn slightly within the base, so I put in a new Polaris bulb. That didn't help,so I traced the wiring and found a cylindrical fuse and a mini-type fuse under the seat.Both looked OK. I did a quick visual inspection of the wiring from the ignition switch to the tail light and can't find anything suspect, so I'm wondering if I might have a problem with the igntion switch or the tail-light socket, or is there something else I may have missed?
Thanks!
Thanks!
bzdok1234
30
02-23-2016 01:55 PM
KimSJoh
14
07-18-2015 07:20 PM
