95 Scrambler 400 - No low end power - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 11-08-2008, 11:08 AM
Default 95 Scrambler 400 - No low end power
the machine runs just fine at idle & once rolling, but, if I'm stopped at the bottom of a hill & go to accelerate, it has no power to try to blast up the hill or at least spin the wheels. Another example would be if I was stopped in some mud or sand & hit the gas, I don't get an instant hit of power lto break the tires loose like before, it just slowly wants to move away, but once rolling, it goes like it should with plenty of power.
Any suggestions as to what the problem may be?
Old 11-08-2008, 02:13 PM
sjbr549's Avatar
sounds like a clutch or belt issue
Old 11-08-2008, 06:26 PM
ftwflh's Avatar
How long have you had this Scrambler?
Old 11-08-2008, 06:44 PM
I've had it for 4 yrs.
Old 11-08-2008, 08:09 PM
scrambler400enoge's Avatar
Shapeshifter Rider
It's a 2 stroke what kinda lowend do you expect?I just love the midrange and topend accelleration on mine because it makes up in spades for the boggy lowend.
Old 11-08-2008, 08:26 PM
I understand it's a 2 stroke, I would just like it to have the low end that it had until recently.
Thanks for the replies, any other ideas?
Old 11-08-2008, 09:39 PM
ftwflh's Avatar
Check the secondary buttons if tyhey are good check the compression.Comp need to be at least 100 psi the higher the better
Thread Thread Starter Forum Replies Last Post
another polaris worn cam question Cole Hadden Polaris 20 07-25-2016 08:32 AM
scrambler clutching performance mitchxc700 Polaris 2 08-19-2015 02:41 AM
PLZ HELP scrambler 500 scram5050 Polaris 38 07-27-2015 01:23 PM
Polaris scrambler maxjung General Chat 1 07-13-2015 05:11 PM
03' scrambler 500 H-O 4x4 Chocobamofo Polaris ATVs - Ask an Expert! 1 07-10-2015 07:46 PM
Tags
100psi , 400 , accelerating , carburetor , comp , end , idle , lack , low , polaris , power , pwower , scrambler , srambler , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
