Polaris Sportsman 500 HO gas in the air box
Old 01-10-2009, 09:45 PM
bjfly's Avatar
Default Polaris Sportsman 500 HO gas in the air box
I have had trouble with my 4X4 running smooth. Changed the o ring on the jet valve in the float compartment of carburetor. Ran it for a minute and it really got rough. Looked in air filter box and gas was coming in from vent hose to the oil box. What causes that, and how do I fix it?
Old 01-10-2009, 10:36 PM
mburnett's Avatar
You might think this is crazy but I had the same problem, changed the air filters and it went away.
Old 01-19-2009, 09:53 PM
bjfly's Avatar
Thanks for your advice. I actually had the bike running with the air box open and watched the gas flow into the box. Ordered new filter anyway and a manual on the machine. I am going to try and reset the float level, drain all of the oil and gas and start over.
Old 01-20-2009, 01:44 AM
BlueRubie's Avatar
Thats the best way to do you can't leave it that way. . .If the fuel is getting into the oil your going to want to flush out the system. . .
Mikey
Old 01-20-2009, 10:05 AM
RyanJ's Avatar
I had this problem a couple months ago. The floats in the carb were stuck so that it was constantly pulling in gas which overflowed out the vent tube into the air box.
Old 01-20-2009, 10:22 AM
MECHANIKE's Avatar
replace needle+seat assem.Ebay,also make sure float dont have gas in it....
Old 01-31-2009, 10:48 PM
bjfly's Avatar
Replaced needle and seat, drained all fluids, adjusted floats and new air filter, runs like a charm now. Thanks for all of the info.
Jmuddin284
06-28-2017 04:59 PM
Gtsordo
07-13-2015 10:38 PM
Shifts
14
07-13-2015 08:41 AM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Shifts
07-03-2015 07:59 AM
Quick Reply: Polaris Sportsman 500 HO gas in the air box
