polaris ranger 500 electrical issue
Old 04-15-2009, 06:01 PM
andrewbaldwin's Avatar
Default polaris ranger 500 electrical issue
I am working on a 05 polaris ranger 500. when you turn the key on nothing really happens. the batery is new and i have good power to the first termination block. the power seperates there and goes to the ECU then its supposed to go everywhere else from there but it doesnt. i was wondering if anyone has encountered this problem i am having. i have no lights what so ever
Old 04-15-2009, 07:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is there any fuseable link in line somewhere or maybe a corroded wire or bad ground?
Old 04-15-2009, 08:19 PM
No lights,no lights on dash either for gear range? If not then you can take ignition switch out,disconnect switch from connector harness and with a test light see if have power going to switch harness. You should have power at all times with key off. If no power to any of the harness wires then probably ECM module bad ( big silver module opposite side of battery) Power goes in and MUST come out,eventhough its supposed to cover fan circuits,etc,it can short out and you can loose all power to ignition and lights! I have one on order for an 05 Ranger 4x4 myself! Not a common problem,but can happen. This is about my 3rd one total! Good luck OPT
Old 04-17-2009, 09:57 AM
Default ranger 500 electrical
ya its looking like the module theres no power at the switch. thanks for your comment it was really helpfull.
Old 10-04-2013, 08:00 PM
Quadrunner455's Avatar
Open ecu up. There are some little black electrodes in there. Look to see if the have any damage. Find them online, in solder them back in. Done this on a ranger with fan not working and saved a man alot of money. Electrode was only around 5 dollars. Polaris said you had to replace the ecu and it couldn't be repaired that way.
ripperray
10-10-2023 02:42 AM
chinkapin
07-14-2016 06:58 AM
txkevin
09-21-2015 02:02 PM
jag6510
06-15-2015 05:59 PM
Steven Bandemer
06-09-2015 08:50 PM
Quick Reply: polaris ranger 500 electrical issue
