Crank pin removal
Old 09-20-2009, 09:34 PM
kellyisu's Avatar
Default Crank pin removal
What is the best way to remove the crank pin connecting the rod to the crankshaft? Best way, as in doing it yourself at home.
Thank YOU!
KELLY
1998 Polaris 300 xpress, 2-cyl
Old 09-20-2009, 10:49 PM
mrtwostroke's Avatar
Well doing it yourself at home is not really an option for most people. you need at least a 20 ton press maybe more. as well some fixtures for supporting the crank as you push it out.
but thats a easy part, the hard part is getting it straight after push the new one in.
which includes some precision vee-blocks, a dial indicator and a a lead hammer to beat it straight. sounds crude but it\s true. The machine shop I work in we charge an hour shop time to replace a crank pin. 110 cad here in BC, Canada
Old 09-20-2009, 10:55 PM
DITTO here in Texas too! Not for the doityourselfer on the crank if you dont have the proper tools. Cost in US dollars a little less at our shop.
Old 09-20-2009, 11:06 PM
kellyisu's Avatar
That's kindA what I was thinkin
jeepwheelin02
1) Engine problems..
07-18-2020 06:42 PM
Divergent12
12-30-2017 08:33 PM
j.graul84
11-06-2015 08:42 AM
Hatrackr
08-11-2015 09:03 PM
toonces
08-05-2015 05:55 PM
Quick Reply: Crank pin removal
