Hall effect sensor
Old 03-26-2010, 11:48 AM
Big600twin's Avatar
Default Hall effect sensor
Anyone else had to change this out. From what I researched this should be my problem. Bouncing speedo when bike is not moving. Dies when put in reverse unless the override button is pushed. Anywhere to get it lower than the dealer???I took it off the wheel and cleaned everything really good but it still is failing.
Old 03-26-2010, 02:23 PM
4getful2's Avatar
try cheap cycle parts, but i don't know if that it will fix your issue.
it sounds like your speedo. is getting feedback from something.
Old 03-26-2010, 04:14 PM
Big600twin's Avatar
I did a fair amount of research and from what i found, a bad hall effect (speed sensor)would cause my problems. If there were more or different issues then it could be the entire speedo. The Hall effect sensor is around $50 vs. $300 plus for a new speedo....I doubt that I'm the first to have this problem and someone will chime in.
Old 03-27-2010, 01:04 PM
chuck_raduenz's Avatar
you can test them.
if i rember. back in 2001 or so mine whent out. it would be varying in speed way to much when i was driveing. said i was going 20 when i was only going about 10. but do the test above. it will tell you if its failing.
Jeff Roper
02-01-2022 11:48 AM
vandammages@gmail.com
08-20-2020 11:50 AM
95scramblerruben1033
09-23-2015 06:29 PM
Jeff Roper
09-21-2015 02:11 PM
Quick Reply: Hall effect sensor
