Need some information on Polaris trail boss 250
i just bought a polaris trail boss 250 r/es
i need some information on a few things...
here is what i know:
it is 250cc
it is between years 85-89
is an automatic
it wont start
its been sitting in a barn for 3 years
prob needs plugs, gas tank cleaned, carb cleaned, etc
here is what i NEED to know:
2 stroke or 4 stroke
where to get an owners manual
where to start trouble shooting
it is 250cc
is an automatic
it wont start
It's a 2 stroke... Mine is a '92 and has a separate tank for the 2-cycle oil just below the headlight. Looks like yours has a tank next to the gas tank...
Sounds like you are on the right track. Empty the old gas, clean the carb, replace the spark plug, check for spark...
No idea on an owners manual, I've got a Clymer manual on order right now.
Good Luck!
Jim
Good Luck!
Jim
If it's been sitting that long, and being that old, I'd do a compression test too. If it's below 90psi, it's time for a rebuild. And since you have to take the carb and all that stuff off, it would save you cleaning it all, putting it back on, finding out the compression is low and having to do it all over again.
The manuals are getting harder to find due to it's age. I know some places you can still download the parts (not service) manual. That's a good thing to have as the parts breakdown is really handy to look at. There may be some places that have the free service manual, you may want to do a search on that here. Can't say that model is in there, but there have been several different ones.
Hope you have it running soon.
It would be Drive neutral and reverse, not parking gear in a Polaris until at least 2005. If it has a low,it would be shift forward while throwing the shifter out towards the right.
I have the same machine, but 4wd. Unless the shifters are different on the 2wd and 4wd models, all the way forward is High, then Reverse, Neutral, and all the way back is Low.
