Broken Polaris Winch? Fix it yourself
Several online sites that have detailed tear down instructions on Warn winches like this one. Warn 2.5ci ATV Winch Breakdown
Plus several videos on you tube.
Thanks so much for the info, I was able to dismantle the assembly and found the handle you turn to enable or disable the clutch is broke.
The winch I have is made by Polaris, I am not sure it's exactly the same, and they don't break down the parts to see the **** you spin to disengage the assembly.
Any ideas?
Any ideas?
Engagement/free wheel **** comes with the end housing assembly. Not sure if this one will work,but says for 2.5 Warn winches.http://www.ebay.com/itm/Warn-21974-Replacement-End-Housing-Clutch-Assembly-for-2-5-ATV-Winches-NEW-/390907767559?pt=Motors_ATV_Parts_Accessories&hash=item5b03eb2b07&vxp=mtr Found the individual part here. Item#12 for $2.49.Hopefully may help.http://www.powersportsnetwork.com/en...tCategoryCode=
Last edited by old polaris tech; 09-28-2014 at 02:34 PM. Reason: found additional parts lists
#16
Great thread, thanks.
I currently have my winch apart, its a polaris branded winch off my 06 800. I think i may just replace the parts anyway based on the cost and i was having trouble putting it into free spool although never had a problem with the unit other than old cable kept getting shorter. Just ordered a new 50' blue rope today.
Thanks again for all the great info.
