Sportsman stuck in reverse
If you've eliminated the linkage,shift box and can't force the gear case lever into neutral then it's possible you have internal problems that have to be checked out. This is normally a stout gear case,but if run low on oil under heavy loads anything could have happened from a damaged internal silent chain,gears or shift fork,etc. Keep us updated as to what you find. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
micheleLeigh
Technical and How-To Articles
07-19-2015 07:32 AM
KimSJoh
14
07-18-2015 07:20 PM
