Sportsman 335 engine shuts off when the gear shift is put in reverse.
No Only time I've had one fail in forward gear is that it would do the same usually as what it would do in reverse and it would die when you placed in gear! It never happened to me,but possible it could limit in forward while driving,but you would just pull the black wire to over ride the module same as you would to solve the dieing problem in reverse(it's a reverse rpm limiter module) OPT
#16
#17
Yes because you are actually fooling the awd system by having it jacked up! That how I always checked if an awd sytem was working correctly, or one wheel was turning only,or neither front wheels turned, etc. Also when you take it out of awd while still jacked up the front wheels should kick out! You may have to physically stop them with you feet first from turning,but they should stop and the back wheels only should turn! OPT
#18
06 polaris sportsman 800
I'm having the same problem with my 800 when I put it in reverse. Does this override trick work on my model too? If so, how do I do it? Also...my speedo jumps all over the place and it also says I have a full tank of gas all the time. Any ideas on how to fix this ?
#19
#20
06 polaris
Your reverse limiter on this model is built into the speedo. You can bypass the over ride button as some have done and see if it helps. Here's the link on it.Polaris reverse overide? - General Discussion Forum | In-Depth Outdoors As far as the speedo jumping around are you talking about the tach or registering the speed itself? If it's the speed problem,then could be the speed sensor on the front caliper shorting out or the protective cap may be dirty.Items 11,12.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Speedo registering full could either be the speedos fault or the float in the fuel pump may be hitting the side of the tank and sticking.I've had to bend the arms a little on a couple of these when this happened.Look at this used assy for sale on ebay as a reference on the float arm.Gas Fuel Pump Assembly Kit 2006 2014 07 Polaris Sportsman 4x5 500 700 800 | eBay
