00 TB325 oil filter..kinda..
Old 05-17-2013, 02:52 PM
1ArmBandit's Avatar
Default 00 TB325 oil filter..kinda..
so i snapped an oil fitting off yesterday(#2) and im trying to get the rest of the broke off threads out...a big problem is i cant get tools into the area very easily...so im wondering, if i take the nut off(#1)..will that whole oil filter housing(#3) separate from the case(#4)?? or is it part of the case too??
Old 05-17-2013, 02:59 PM
You just need to invest in some deep metric sockets(or at least the one for this fitting) as it helps holds this assembly together.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old 05-17-2013, 03:20 PM
1ArmBandit's Avatar
yeah its a 21mm i was just making sure that part came off(#16 in your link) and speaking of #16, why doesnt it show it in the list, what is it called? just in case i mangle it trying to get the rest of those threads out i wanna know how much it is...
Old 05-17-2013, 03:34 PM
Try not to mangle this part!! Just get the broken oil line fitting out. A lot of places no longer carry it (3086402) and the only one I found so far including Ebay is at Partszilla. A little over $88.. A $13 fitting is considerably cheaper!
Old 05-17-2013, 03:41 PM
1ArmBandit's Avatar
lol, yeah, ill be trying my hardest not to mangle...ive got a reverse thread tool screwed into the broken part but its super tight and it feels like if i screw any harder it might crack around the hole
Old 05-17-2013, 03:50 PM
Use some heat and some PB blaster and it should come out.
Old 05-17-2013, 10:51 PM
1ArmBandit's Avatar
i drilled n tapped, shes all back together n runnin
Old 05-18-2013, 04:07 AM
1ArmBandit
04-30-2013 12:10 PM
1ArmBandit
01-11-2013 12:26 PM
Screw
05-30-2002 11:54 AM
WhoDatInDaMud
03-10-2001 12:32 AM
DaBoss
02-21-2001 02:43 PM
Quick Reply: 00 TB325 oil filter..kinda..
