grease fittings
grease fittings
Hi all, longtime lurker, second time poster!
OPT I have a question about grease fittings, My 02 sportsman is missing one on the front left lower control arm, not that it was there but there isn't even a hole. My question is how were they mounted just drill a hole and thread it or do I have to weld a bung on to put one on?
Thanks for your time.
Don
Great site, lots to read and absorb
Don
Your model came equipped with grease fittings (7080433) but if it's ever been replaced it's possible the superceded part number omits it. I've had several a-arm replacements that came in that went to the latest model,ones without the zerks and bushings were changed also! It's a threaded zerk fitting. I believe it's a 1/4-28 and available at any auto supply. I just tapped em out and installed the zerks I had in stock to match the other side that had one. Easiest thing is just take one out and match it up if you have to. http://www.cyclepartswarehouse.com/f...2002&fveh=5582
Owners manual shows the locations in the maintenance section. You might try here to see if you can download one.Polaris ATV, Snowmobiles, RANGER, Victory
Plus a good service manual has most zerk locations also.https://www.tradebit.com/usr/tradema...pairManual.jpg
Herb
