1997 Sportsman 500 oil change?
k just to confirm - I posted a picture of the tube I am planning on sqeezing and pointed to where I will clamp it with vice grips. If I clamp the hose in this location and let the bike run for 2 minutes I will not harm anything and I will be good to go after this? even if I do not here a hissing sound? good to go if I do this?
Wrong tube!! This is the oil return line from the engine. Look way at the top of the oil tank(may have to feel) there is a hose leading from it to the air box. This is the tank vent line. Clamp the vice grips close to the tank vent inlet pipe,run the engine for a couple minutes and release the vice grips.You may or may not hear air hissing from the tank,but the oil pump will be primed. The line at the very top #5.
I squeezed the tube I was pointing at for about 45-60 seconds while running the bike did I ruin my motor?
#16
#17
#19
Sorry about your Grandfather. The tank is located on the left hand side as you're sitting on the machine. Has a yellow dip stick on the tank.Crank it up for a couple minutes,kill it,let it settle a couple minutes and pull the dip stick. Wipe it off and screw it all the way in. Pull the dip stick out.Has a low mark and full mark. Oil level should be on the full mark or a tad below.
#20
