Sportsman 2005 twn Just Purchased..should i change Fluids 42 Run Hrs?
Hello Everyone,
I am new to your forum.
I just purchased (from Friend) a 2005 Polaris Sportsman 700 Twin for my son.
It has 42 Run hours and 235 miles on it. Original owner only used it for plowing his property and light trail travel. Obviously he didn't do much of either
I would like to have the fluids changed. (either myself or dealer) He said he had it done 12 months ago.
Is this simple to do for a weekend mechanic?
Do you think it is necessary at this point? Also, would you recommend that I take it to a dealer for a check up?
Thanks you for your help.
Mike
Mike
If I just bought a used one no matter who from,I'd do a service for peace of mind.Only oil you can differ on is the engine oil itself.Some still use 0w40 Mobil1 or Amsoil, or any good Synthetic 5w40,5w50.Use Polaris designated oil for the transmission and front diff,can't find any much better.Plus oil filter choice is wide open other than Polaris #2540086 (700/800 engines) and #3084963 325-500 engines.
Motorcycle Filters.
None are recommended.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
Wal-Mart SuperTech ST6607
Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
Automobile Filters,
about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters,
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Automobile Filters,
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Millard ML-3593
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
If this isn't enough,here's another list of filters that interchange and work on other machines.http://www.oilfilter-crossreference....OLARIS/2540086
If you don't have a manual,here's one well worth the 5 bucks. Service and intervals are straight forward and can save you trips to the dealer on other service and repairs.http://polaris-atv.brssm.com/2005-Po...ce-Manual.html
Also if you have the carb model 700,make sure the ecm module (under the front panel) is a silver color Sure Power module and not a black finned Chinese module. PO may or may not have had this recall done. http://www.usrecallnews.com/2008/02/...scrambler.html
Motorcycle Filters.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
Honda 15410-MCJ-000
NAPA Gold 1358
STP SMO 17
WIX 51358
All have superior
filtering.
Made by Champion.
Made by Champion.
Made by Champion.
Made by Champion.
Made By Champion.
Automobile Filters,
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WIX 51365
Automobile Filters,
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Deutsch D-370
Fram PH7317
Automobile Filters,
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Millard ML-3593
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
Well no one here I dont believe will have more knowledge than opt, I think he wrote the polaris bible.
Now from my far inferior knowledge I learned a very expensive lesson. I change my own fluids and it may take an hour for all 4 fluids and filter. Once u do it along with your son it will be easy.
But, if you take it to a dealer maybe once a year they will look at other components u dont think about, in my case my bike didnt go to a dealer for 3 yrs I did all the changes about 5-7 times a year with my type of riding and that can be very expensive for a dealer to change the fluids that often. My motor mounts were bad causing major damage to shaft ans bearings and that was a 2500 bill along with a few other things. If I had taken it in prior the mounts are only about 35 each and 1hr of labor could have prevented my failure. The 200 or so theycharge for a fluid change to me is a good piece of mind and I hate spending that much for an oil change and I have 7 bikes.
good luck
good luck
Thanks for help...going to take it to dealer for first tune u
Thank you very much for your help. My son wants to ride this weekend at the hunting lodge so I am going to take it to a Polaris dealer this first time. I don't have the time to get the manual before then.
With 42 hours, I don't anticipate any major problems...(I hope)
Thanks again
Mike
Thanks again
Mike
I take it the twins use the same oil filters as the single then?
42 hrs and its on its second oil change, I don,t think I,d bother doing anything but ride.
235 miles is like two and a half tanks of gas.
A dealer will charge you $200 to tell you their is nothing wrong with it.
Search Results for 3084963
Part Number Manufacturer WIX Part Number
3084963 POLARIS 51358
Part Number: 51358
UPC Number: 765809513587
Principal Application: Honda Motorcycles + Industrial Engines, I-R, Komatsu, Kubota, Kia (95-05), Mercury, Arctic Cat, Nissan (06-10), Polaris, Subaru (06), Yamaha, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=13/52
Burst Pressure-PSI: 265
Max Flow Rate: 8-10 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Search Results for 2540086
2540086 POLARIS 51356
Part Number: 51356
UPC Number: 765809513563
Principal Application: Acura (02-10), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-10), Infiniti/Nissan (96-10), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-10), Saturn (04-07), Outboard Marine Engines, Various HD Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Max Flow Rate: 9-11 GPM
Gasket Diameters
IMHO I would change the fluids,and do it myself.Its not a difficult task.This way You know when they were fresh and when to change them again.As far as bringing it to dealer hoping they will give it a once over when you bring it in for fluids,dont hold your breath.Educate yourself on what to look for,ie bad or noisey bearings,cv joints,u joints,tie rods,all those things are easily checked for wear and tear.
