Fuji 455cc valve adjuxtment.
Pull the valve cover, side cam cover and the spark plug since you don't have a recoil starter. Bump the engine over to where the cam sprocket alignment pin is close to the center of the head.With the spark plug out it's easy to physically turn the sprocket to where the sprocket pin is at tdc,plus you can pull the stator cover 14mm bolt if you wish to see that the inverted flywheel "T" mark lines up with the case pointer indicating tdc. Most times valves are set at a loose .006 from the factory. May end up just checking clearance and find they are ok.Most times if you don't tear up the gaskets taking the valve cover and the rectangle cam cover off you can reuse them.
When I checked my 500 sportsman , they were quite loose. I set them at a loose .006 but found the engine still rattled under acceleration. I read that some adjusted to a snug .006 and the engine quieted down some. I tried that and it's better, well a little more quiet I mean. If your exhaust valve rocker is like mine where it does two valves with one rocker, make sure you set them together. Two feeler gauges at the same time. It's not a hard job , it's hard to get at the area though. A lot of plastic in the way on mine anyways!
Scooter's Shop
23
10-22-2015 07:04 PM
