2004 Polaris Sportsman 600 twin 4x4 Tranny Grind
Try lowering the idle,plus if belt is grabbing the rear clutch or if it creeps in gear, hard shifting can happen.Plus this model transmission was bad on water entering the small gear selector cover corroding the gears. This alone can cause sticky, hard shifting. Part #3 is the cover and gears behind here were full of grease from the factory.
Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
bzdok1234
30
02-23-2016 01:55 PM
