How much can I shave the head on a 400?
I just picked up a 95 xplorer 4x4 for cheap. There was only 90 psi of compression. I pulled the jug off and sure enough the piston was damaged. I have a 84mm wiseco ordered. I'd like to get a little more power out of her. How much can I shave the head to get more compression and a tighter squish. I know on some other two strokes I have (banshee & blaster) that a .040-.050 squish is optimal. I'm thinking the same rule applies to this machine. I'd like to get the compression close to 150psi so pump gas can be run.
jrooker6
04-23-2016 07:36 PM
1ArmBandit
55
10-14-2015 09:03 PM
Quadzilla Heritage
09-25-2015 01:39 PM
09-23-2015 06:23 AM
