330 Magnum fluid change
Thanks very much but you mentioned two different drain plugs, #18? and 7/16" Im not sure what you are referring to? Is there two drains on the front area?
Do you know what I need to buy as far as size allen wrench for that front plug? Im not familiar with any of this.
This is a 2003 Magnum 4x4
Polaris use "Standard" on the chassis and "Metric" on the single cylinder motors.
2003 330 Magnum 4x4s either had the visco-lock dif or the roll cage system not the hub awd system.
Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
The sites wrong.Even one model of the 2002 Magnum 325 had the visco-lock diff along with the 2002 Sportsman 700 roll cage model . Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
PSN is just showing the 2003 models that still had he hub mounted awd systems,but didn't show the complete line.
#15
I got the front diff changed with the demand drive fluid. Had to use a small piece of fuel line hose attached to the bottle od Demand drive fluid to get it in to the fill hole. Spilled a ton all over the place.
Spent over 2 hours trying to locate the drain plug for the transmission but could not locate it. I think I have the fill plug located. I even jacketed the 330 up to get under it with a flashlight. Still could not find any drain plug. There was one Hex head that was up inside but sideways, not flush with the bottom like the motor oil drain plug. Is it possible that this machine doesn't even have a drain for the transmission ?
#16
7/16" Drain plug can easily be over looked as you really need to feel for it. It's at the front cover down low. Almost looks like it's one of the case bolts,but has a small washer behind it. Cover is #48, drain plug and washer is #46,47 though the numbers are hard to read. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse And yes the drain plug is mounted on the lower case side, not up side down like some drain plugs.
Technical and How-To Articles
08-21-2015 09:31 AM
