voltage regulator question
so i think i found my culprit it would seem as my voltage regulator is bad/ going bad so this morning i switched out plugs with a brand new one and this time i gaped it to specs the .70 mm and put it on right and went to fire her up and no dice so i ended up pull starting her so i went and did all my chores on my farm right, and when i pulled into my garage i said to myself let me get my multimeter out and check again to see if i can figure it out so then i pulled my manual out and started to read it right and under voltage regulator there is a test, it said for me to put my multimeter in the 25 dc range and connect my black lead to a known good ground and then take my red lead and connect that to the red wire that comes from the voltage regulator and it says that anything below 13 or above 14.8 then it is bad and it said to not accelerate the machine anymore than necessary to get your readings and i had to nearly redline her to get 12. something and it never did get over 13 so im going to have to say that that is my problem. what do u guys think?
THANKS
RUBEN
THANKS
RUBEN
You mentioned it got to 14+ volts at the battery with regulator hooked up? Do an AC test to eliminate the stator as a problem. Turn meter to AC amps, red lead to 10 amp input,both leads to the yellow and yellow/red wires. Start the engine,at an idle ONLY it should show a minimum of 5 amps. If the stator checks out ok and you want to try a regulator,here's a cheap one for $25. Old part#4060087 (4060193 new #) Rectifier Regulator Fits Polaris ATV 4060193 4060087 New | eBay
Plus if you haven't already pulled the black wire from the limiter module (located to left of the reg/rectifier) do this and see if it still runs the same.
no now here's the thing with that i did try the ac amperage test but i think my multimeter is messed up as far as that goes because the last time I tried to check my battery i accidentally had it set for ac amperage check and now when I try to do a test i get sparks from one of the leads and the most i get is .03 that can't be right can it ? I mean especially since I just bought a brand new oem stator .oh and the black wire from the rev limiter has been unplugged.
Thanks
RUBEN
Thanks
RUBEN
#15
#16
I'm with you on the new stator as probably being okay.. Unless you get another meter and test the ac amperage to make double sure. Cheapest thing at this point is the regulator and that's what I'd replace. Again I may be wrong on this,it should solve any charging problem you have,but not sure as to the power loss you complain about as it warms up. I've just seen so many two strokes start to loose compression when hot and either run like crap or die until they cool off again.
#18
0k well it would seem that my problem is gone so 3 days ago which is sunday morning i decided to put a new plug in my machine and when i did so i also decided to unplug all of all my trail tech vapor wires from my machine. and i threw the battery on the charge over night well needless to say my machine has not backfired since sunday morning meaning that was the last time that she did so and shes firing right up. so i have ordered a new voltage regulator anyway new is new right.
BUT I AM PLEASED
THANKS
RUBEN
BUT I AM PLEASED
THANKS
RUBEN
#19
#20
