Shifter & Speedo / AWD Questions
New here, just bought a 1999 Sportsman 500. I have a couple of questions...
The shifter works but you can spin / twist the handle. Is there a pin that could be sheered to let it spin?
Also, I had to put a starter & battery in it. I have the classic no odometer, low beam or AWD light working. Is it safe to bet the speedo head needs repair?
Thanks in advance for the help,
Chuck
Chuck
Possible screw backed off in the handle grip? Item#2.
Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Don't overlook the plastic sealed 20 amp circuit breaker up from the battery if you don't have power to the dash,lights,etc. Test for voltage on either side of the wires leading in and out,plus if in doubt you can slice the pouch open and check for corrosion on contacts. These are cheap at most auto stores. If you rule out the circuit breaker,I'd check the connections at the spedo and under the front panel especially around the high beam connector and main wiring harness that takes a lot of stress from twisting and turning.Also check the connectors going into the left control switch. Could be as simple as that they need cleaning,pins not making good contact.
If you have power to the ignition switch and lights then the circuit breaker is okay.Lower lights are low beam and bad about blowing the bulbs out.Each one of the dash lights are sold separately if needed if you look at the break down. The 2nd year model digital speedos on these weren't the best and expensive to replace.If you have someone that can rebuild one reasonable then you might try that. You can also try regrounding the awd wires under the front panel and see if at least you can get the awd working.If successful the awd switch should light up. Here's one posters video on doing this.
Only one person that I know of has done their own and posted pics. This is from a later model. AWD and Speedometer don't work - Page 2 - ATVConnection.com ATV Enthusiast Community Plus you might google spedo repair sites. If it gets too expensive,then might be best to bite the bullet on a new one.
