Magnum 4x4
Magnum 4x4
Trying to get the 4x4 working on my older machine. It's a 2002 Polaris Magnum 325. Bought it as a project machine as it has more problems then I can count. I'm having to replace the electromagnetic coils in the hubs, but before I do that, the 4x4 switch lights up when I switch it on, (and current goes into the wires for the hubs) but when you give it a bit of gas the light goes off until you let back off the gas. Does this sound like a ground issue? Or is the switch not getting enough power? Thank you for your reply.
Check the connectors and wiring on the transmission switches as they transmit gear position.Plus if gear position input is erratic so can the awd light and power to the hubs also.Could just need cleaning and a little electrical grease.I'd eliminate this first.If it still has problem,may be the small grounding wires for the hubs at the two connectors under the front panel loosing ground. Possible you can do as some have done on the Sportsman 500(same system) by making a common ground on the small awd wires to a good ground spot. Also if you have the speedo version of the Magnum(FB),the awd wiring runs through it.Jump the brown/white wire to the brown in the speedo connector which bypasses the speedo as far as awd.
09-09-2015 06:57 AM
