outlaw carb question
Old 02-01-2015, 02:29 PM
ultrakillpv's Avatar
Default outlaw carb question
for the fcr carburators they have the throttle position sensor on it does anyne know what will happen if i run it with the sensor not plugged in? can it be ran effectvely without it? what are the effects of running it with out the sensor cnnected?
Old 02-01-2015, 02:35 PM
Old 02-01-2015, 03:19 PM
thanks that all helps so the tps connects to the cdi and i ask this is because on mine i have a cv carb and i want to switch to a fcr and so far that i have found ill need to upgrade my cdi to run the fcr carb on my cdi it only has a single port and wont have the extra for the carb so is this correct?
Old 02-01-2015, 03:24 PM
I guess as I've never swapped carbs on the Outlaw at the shop. Had enough problems just keeping the Outlaw and the Predator repaired and running from all the crazy people that bought em..
Old 02-02-2015, 02:01 PM
quick question on jetting my carb my evelation is around 2,600 above sea so what size jetting should i use i have a silp on and filter w/out lid?
would jetting be the same for both cv and fcr carbs
Old 02-02-2015, 02:34 PM
Two different types of carbs. Jetting will be different along with other things. If you're getting a new carb designed for this use it should have some sort of jetting guide.Plus this might be able to help you.carbkie.html, Keihin FCR Carb Tuning Procedures
Jmuddin284
06-28-2017 04:59 PM
200es
07-10-2015 09:09 AM
tweeder
07-05-2015 01:57 PM
yambam13
07-04-2015 01:49 PM
Mikea1978
07-04-2015 12:37 PM
Quick Reply: outlaw carb question
