voltage regulator question
Old 02-24-2015, 04:34 PM
95scramblerruben1033's Avatar
Default voltage regulator question
yes hello i have a question regarding voltage regulator. can i simply take it off and will my machine still run. i ask this question because it turns out the replacement that i bought is bad . and they want me to return it.
THANKS
RUBEN
Old 02-24-2015, 05:21 PM
Yes you can remove the regulator as long as you don't mind pull starting it only,doing away with the lights,as they will blow anyway,plus don't mind not having awd,plus you might as well chunk the battery. The lights,starter have to have the battery as well as constant voltage for the awd and what keeps the battery up is the regulator..Plus you may need the fan to keep the engine cool as it will get hot..Kinda of a Catch 22 on this one,gotta have one. Think I'd return it as most places won't take electrical parts back.Think I'd jump at this to be able to get a good one.
Old 02-26-2015, 10:04 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should not run it w/ out the reg. as for reasons stated above
zPuls3
1) Engine problems..
09-12-2015 08:54 AM
TheATVSuperStore.com
TheATVSuperStore
09-09-2015 07:43 PM
MrTrashMan2U
09-09-2015 11:11 AM
Bigtwin700
09-09-2015 09:32 AM
Rooky
09-09-2015 03:16 AM
Quick Reply: voltage regulator question
