04 sportsman 400 late model
Hello, I put a new battery in the 400 and now it says it's running hot and the fan wont run. the fan is good because if i unplug it it will run off of a battery. Even after it sets there and becomes cold you can turn the key on and it flashes hot. It seems like this happened when it was under warranty and they had to replace some sort of electronic component.
Sounds like the temp sensor is faulty if it shows hot even when the engine is cold. Since fan shows ok when hooked up direct,I would suspect the sensor itself.Item #2. Shows $64 here. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse But can get it for $44 on ebay.http://www.ebay.com/itm/Polaris-Sportsman-400-500-Hot-Light-Thermo-Temp-Switch-3085352-/160993723755?pt=Motors_ATV_Parts_Accessories&hash=item257bf9456b&vxp=mtr Plus you may be able to match it up cheaper at a local auto store. IF the fan doesn't kick on at all when hooked up to the harness,could also even be the radiator sensor.Item #21.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse even these can be substituted by an after marker sensor like Wells#526 and just splice in your connector.Wells Vehicle Electronics Cooling Fan Switch SW526: Advance Auto Parts
If you have the AQ model 400 with the ecm module and not the AA,the one with the regulator, then YES,I'd check into the ecm as this one changes also to the newer US made module! All the Chinese ecms are junk including ones like yours that weren't on the recall.Controls charging,fan,battery protection,hot light,etc! Item #30. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse http://www.ebay.com/itm/2004-2006-Polaris-Sportsman-and-Scrambler-400-450-500-OEM-Surepower-ECM-2005-PDM-/171576768506?pt=Motors_ATV_Parts_Accessories&fits=Make%3APolaris&hash=item27f2c5b7fa&vxp=mtr
John Boy
07-13-2015 11:16 AM
