2002 Polaris Sportsman 500 HO Ball Joint
Old 03-11-2015, 11:39 PM
NobleEagle's Avatar
Make sure the strut is cool to the touch before you install the new seal. Plain old bearing/race tool set works fine or a same size socket and extension. Be sure to mark around the old seal before you pop it out. This is a good guide on how deep to drive the new one in.
thanks for the tip I intended on letting it cool. as far as marking it, it seems as though it is flush as in there is no where to mark the depth.
Old 03-12-2015, 05:00 AM
Mark around the circumference of the seal that's inside the strut.Just clean the oil and grease around it.This the stopping point on the new seal.
Attached Thumbnails 2002 Polaris Sportsman 500 HO Ball Joint-71b6p2qxktl._sx425_.jpg
Old 03-12-2015, 05:50 AM
NobleEagle's Avatar
gotcha I'll take another look but it seems as though it's flush and nowhere to mark or score.
Old 03-17-2015, 02:06 AM
NobleEagle's Avatar
UPDATE: I fixed the ball joint, the new seals, re packed the bearings, replaced the fan, and replaced the f/r axle. I took it out on Saturday and had a blast. I did a bit of trail/sand/mud and climbing. It all held together pretty nicely. No problems whatsoever (other than top siding and not able to get our without some help. 4WD only works if you can get traction lol.
  #15
Old 03-17-2015, 06:15 AM
Now you'll know what to do if it happens on the other side.
  #16
Old 03-17-2015, 11:59 AM
NobleEagle's Avatar
Yes OPT and I've learned a lot from you. Thanks
  #17
Old 03-20-2015, 06:47 PM
jacko76's Avatar
Default boot repair
does anybody have a good video on replacing outer front boot on a polaris 400 2005.
  #18
Old 03-20-2015, 06:59 PM
Several videos on you tube. You don't have to pull the drive shaft out,just get out out of the strut to change a cv boot,but for some it's easier on the work bench.This is from the rear,but basically the same.Just pull out the strut a little,wiggle the cv out of the strut,remove the clamps,slide up the boot and with a brass hammer or dead blow,knock the cv off the shaft. Slide off old boot,on with the new one ,then tap the cv back on the shaft,replace the clamps.
Jmuddin284
06-28-2017 04:59 PM
bzdok1234
30
02-23-2016 01:55 PM
coolguy420
07-10-2015 01:17 AM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Shifts
07-03-2015 07:59 AM
Quick Reply: 2002 Polaris Sportsman 500 HO Ball Joint
