I need help with my polaris trailblazer 250
Well okay there is no battery the start wires solenoid all is disabled you pull start an it has very good spark itl light you up if you touch it it runs but only for like 15-30 mins then it bogs out an it wont start back up for a long time I just rebuilt the carburetor an it still wont start like it should and theres gas getting to the spark im confused its somthing so simple I just dont know what it is
What does the spark plug look like?
What do you mean that the spark lights you up? Does is have a decent blue spark when you hold it close to a ground?
Next time it bogs out and dies, check for a strong spark
Sounds like you'll need a top end rebuild. It might feel like it has good compression but low compression is most likely why it's hard to start.
I assume this all happened before you first rebuilt the carb?
Sounds like the oil injector isn't working or the banjo bolt might be clogged. I had that happen on my 400. Make sure you're getting oil before you spend money on the rebuild.
