Compression test range SP500
Well I got quite a surprise tonite! Got the front plastic off,tank ect... Pulled the rocker cover,intakes were tight so I adjusted them and rechecked the compression and no change so I started to remove stuff for a top end pull and when I unbolted the exhaust at the head I was shocked at the clay water dripping out the head! They tried to start the ATV for quite a while when they got it out the water but it never restarted once it cut off and most of the water entered through the exhaust. I saw the oil that come out the motor and it had a very slight hint of water in the oil but it was not milky, the crankcase breather hose looks clean. I'm debating on just doing a top end job or do a complete tear down? Most I've been into and split cases were no brainers,they had been run and were full of water but seems like a majority of the water and mud got on top of the piston and the cylinder got damaged from trying to start it or got distorted from the rapid themp change causing a instant loss in compression
Once you pull the cylinder you can tell pretty quick on condition of lower end.If there isn't water in it,possible just to go with the top end rebuild.Plus you could always drain the crank case, fill the bottom end with kerosene,roll the rod around and drain the crank case.Throw some cheap oil in the crank case,roll the rod around again and drain. If there's any small amount of dirty water in it this should flush it out.
#15
#16
#17
#18
Well got everything tore down, lucky a friend has a ultrasonic parts cleaner to wash everything up,not as much mud as I'd thought but enough to cause major damage,broke down the oil pump,cleaned and checked the clearances,so far so good. Got a gasket set ordered, cylinder and head are heading to the machinist tomorrow. If I have time I may put the case back together before the weekend. Shooting for 2 weeks tops to get him back running
#19
#20
