Compression test range SP500
#21
nothing is supposed to go in from the inside of the case, there is however the anti-drainback valve just on the other side of one of those holes. Should pull it out and make sure it moves freely and isn't torn up.
I didn't take it out and it ended up binding when I was priming my fresh engine. It didn't allow oil to get to the motor so i had the pleasure of rebuilding it a second time. Just put some oil in the crankcase when your assembling it too so everything has lube.
#22
#24
Thanks again!! I may put the case back together tomorrow evening, I was surprised the cylinder only needs honed considering it's an 02 model but it had been well serviced,lucky it never started after the mud got in it, new std rings on order from the local dealer, not sure about the valve/head condition yet. Ordered a Athena full gasket set, I hope the quality of this set is pretty good especially the head gasket, most aftermarket sets I've used have been trouble free
#27
#29
#30
