Sportsman 500 belt noise
All depends on how it's been driven. If you used low range when necessary,didn't lug the engine or clutches down,then possibly the belt was the problem. Just see how it runs with the new one.The rear clutch isn't that hard,just need a big pair of circlip pliers to remove the snap ring. When you remove it and raise the helix the clutch spring will unwind.If in doubt the manual shows you how to replace them and rewinding the clutch,spring settings or you can just pull the clutch off and have a dealer replace the ramp buttons if needed.Most times they can do it about 15 minutes or so.
trouttracker
07-20-2015 11:54 AM
