ATP 330 oil change
ATP 330 oil change
Friends that I camp and ride four wheelers with have a 2004 ATP 330. Since they are not too mechanically inclined, they asked me to change the oil in it for the summer season. Is this machine similar in service as the sportsman 500 as in you drain the tank and the lower crankcase, pull the fitting on the tank to clean the screen and prime the pump after the oil is added? They picked up the oil change kit so I am assuming it take 2 quarts like the 500 does. I am going to grease it while i am at it also, are there any hidden fittings I should be aware of?
Thanks,
Mike
Thanks,
Mike
