Outlaw 90 HELP NEEDED!!
Cover has to be on as the bearing stabilizes the clutch. The starter idle gear(that works off the starter) will bind up with the starter gear. Items 2,8 on the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Check that the cover bearing is not worn,turns ok. If not replace it. Plus not a bad idea to clean the kick starter assembly and oil it while you have the cover off as it can get stuck by belt dust over time and won't retract if you have to use it. Can't see the video,plus on a new machine,best to have the manual to help. Here's a cheap one for 5 bucks.http://polaris-atv.brssm.com/2008-Po...ce-Manual.html
