another polaris worn cam question
#21
Feel the radiator hoses to see if they're all hot. Radiator could be dirty and need to be washed out especially around the back side. Plus you can do a radiator pressure test. Must hold 10psi. If it leaks down could be because of another blown gasket,a warped head or cylinder causing the problem.
#23
idk how it ends but my 1998 sportsman 500 4x4 will blow into the overflow when I rev high read up on several things about it and one I think is with my case waterpump bearing (if bad or going out can let crankcase pressure though and blows out at full throttle
toonces
10-16-2019 12:11 PM
