PLZ HELP scrambler 500
Do you see any coolant coming from the water pump housing? I should have a weep hole to let you know it its a seal problem.
Not sure if the H.Os had the cam problems?
The 500 Scrambler got the High duration H.O cam in 1998 where as the Sportsman did not get it until 2001, two years later.
hey there no coolant leak from anywere other then coolant jug when it starts spewing out when its over heating i started leaning towards blown head gasket but i have no coolant in my oil no white smoke from exuast and no smell of coolant when quad iis running am i looking at a rad problem some fins are crushed and it looks pretty dirty and pluged and thats what i can see just from looking i could imagine whhat it looks like if i pulled it out of the quad
Yes they had cam issues on the early Scramblers,but don't think that's the problem of over heating. Pull the radiator cap,elevate the front end and let the engine run and fan cycle on and off. Should see coolant moving in the radiator a little plus check for any leaks under the water pump housing or elsewhere. Could be a trapped air issue if the coolant level drops in the radiator. May just need to be topped off after that. Also something simple as needing a new 13 psi radiator cap could be the problem. If the fan doesn't kick on,could be a faulty radiator sensor or the fan circuit breaker under the front panel causing this which can cause one to overheat.This was one of the last models to have the sensor at the top of the radiator and could short out if coolant got too low stopping the fan from operating. Item #15 Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse And yes if coolant has run low long enough it can melt an impeller from cavitation. Just check the fan operation and for any trapped air or leaking first.
#15
If it's bubbling then it still has air. Try squeezing the hoses and lifting the machine a little higher to see if it helps. You can do a pressure test on the cooling system and see if it holds 10 psi. This way you can tell if its in the cooling system sucking air or a small leak somewhere. Also again doesn't happen often but impellers can melt from cavitation and heat or the nut can back off causing flow problems.Plus yes what TLC said on the radiator behind the fan. Another common area that people over look.
#16
#17
basically what they are saying about the rad being blocked would be on the fan side. if you look at the rear side of rad and it has mud packed in the fins then it could be part of the reason off the over heating. also as opt mentioned if there is any air in the system it will cause over heating as well. if you carefully run your hands up and down the hoses from the engine it should be the same hotness to see if the impeller is working or not and to see if the coolant is circulating.
#18
yes this may be what is happening id like to post a pic to show you guys what it looks like to get your oppinion on if you think its to dirty or maby im just hoping for a simple souloution lol if you know how to post a pic let me know and i willl
#19
#20
just looks empty my cool aslo boils in the rad when i come to a stop i hear a hissing sound ffrom rad no steam though
