xpress 300 engine problems help!!!
cylinder
Well I just went and looked at the cylinder. And you can clearly see were the rings are not touching the cylinder. So it is egg shaped. I think I am going to go with the Wesco 76.00mm that will be .060" overbore from the original of 74.50mm Is That Right? What is the gap to be at between the piston and the cylinder. another ? Can the oil injectors be rebuilt? Because after I get done rebuilding the top end and putting new bearings and seal in. I'm not going to have the money to buy a new one. Or even a used one. So If they cant be rebuild. I will just have to start mixing the gas and oil.
cylinder bore
Well I just took the jug to the shop. They said that it has to go to 76.50mm because it is so egg shaped. That is the max it can go. He also said that the clearance should be around .005"-.010" on the new piston. I ordered the piston it should be here tomorrow. so when it gets here I will take it to the shop.
This guy is nuts if he thinks the piston to cylinder clearance should be this much!! .006 clearance is what's considered worn out..If that's what you'd have,then it's either time to have the cylinder sleeved or get a used one from ebay.
#15
well see. That's what I thought. If you put a feller gauge on one side of the piston it should be .004" That way when you center the piston with the rings. You will have .002" all the way around the piston. when I take the new piston to him I will make sure he knows about the clearance's. Or I will take it some where else. And I have another jug that is standard. So If I have to ever re jug It I have a spare. He said it was egg shaped about .003 over the recommend tolerance.
#17
Well I just took the cylinder and the new piston to the machine shop. It clearly state's on the piston box .0030" Clearance. I made sure that he new that. And I told him I will be checking it when I get it home. He said He will cut It to .0030" And after I get It back and every thing is ok. I will be needing some information on the crank bearings. I still need to get the bearing off the crank. I have to figure out how to get the worm gear off. I don't have a bearing splitter. I might make one. What do you think?
#18
Easier just to get a cheap 9 buck bearing separator. Will go behind the bearing to where most pullers can't and will remove the bearing and the worn drive gear at the same time after you heat the worn drive gear up.Plus you may find other uses for it later on. http://www.ebay.com/itm/New-Small-Bearing-Separator-Splitter-Puller-2-1-4-Remover-Separators-/321618588491?hash=item4ae1f6334b&item=321618588491&vxp=mtr Probably can find one at Harbor Freight,Northern Tools,etc.
#19
well I just got the cylinder back from the shop. And It looks good. I checked it and the clearance is 3 thousands. And I got the bearings. The one on the stator side has to go on first because of the worm gear. But how would you recommend how to put the other bearings on. Should I put them on the crank first. Then freeze the crank and heat up the case. Or should I put them In the case. Should I heat the case up? Or press them in with a press? I have a 20 ton press. If I press them In. And I don't get them just right. It could shave some metal off of the case or bearing. If I heat the case the bearing should drop right in. Then heat up the center race. And the Crank should drop right Into those. As long as the crank is chilled. So what do you think? I would like your Input. I have to much money tied up In this to mess it up now.
#20
Should I put them on the crank first. Then freeze the crank and heat up the case. Or should I put them In the case. Should I heat the case up? Or press them in with a press? the center race. And the Crank should drop right Into those. As long as the crank is chilled. So what do you think? I would like your Input. I have to much money tied up In this to mess it up now.
