330 makes loud knocking noise
my buddy got a used 03 magnum 330, it has alot of valve noise, adj. valves and still has alot of motor noise, noticed the oil line to the cooler is leaking and does not have a crimped on line on the upper oil line like the lower, book shows both have crimped lines, so the other day the line came off and they drove it for a mile or so, now when u rev it up it sound like theres someone inside the with a hammer tring to beat his way out. what do u think, bad motor, needs complete overhaul, any good motor rebuilders out there or trash.
Just pull the recoil,flywheel and stator(let stator stay on the right floor board) and engine comes out the left side. A little easier if you remove the breather cover,will have more wiggle room to tilt out.Item #6. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
